Rear Disks
Better off with the proper renault supplied parts, or at least you'd need to paint the bell of the disk as those would rot/rust and the proper renault ones will come already protected. Not that much more surely are they?
I think the proper Renault supplied parts are £83.03 each http://www.allcarpartsfast.co.uk/renault/renault-8200736267-brake-disc-single/ then i would just need to buy the disks as well after reading a bit on here it seems a lot of people go for the Brembo rear disks http://www.nextdaybrakes.com/info-p...ts&engine=2.0000&year=2007&search=Part+Number does that sound about right? any recommendations as to which would be a better setup?
You could get grooved/drilled/dimpled from Mtec with a set of Mintex pads for a fiver less delivered.
I only went for the drilled, but they do pull up extremely well, and the Mintex pads don't dust up too badly.
You do get a slight buzz noise from the drilled discs when braking, it's the air pockets, only just noticeable with the window open.
There are some pictures in my project thread towards the end.
Think I might go for the MTEC Disks Drilled with the Mintex Pads for the rear can get both for £142 with the 15% discount code on the MTEC website seems a bargin
