Hello, i have a problem with my clio III 197 with the fuses.
The fuse of the air was embedded and when i remove with a screwdriver the faston wasnt in her place.
In the photo You can see how the one on the left does have the faston and on the other hand the one on the right is empty (from there I also took a fuse)
The one on the right was embedded and is the one that lacks the faston and does not have any cables behind it. It's the air fuse and it's been failing me for a while. Does anyone know what's going on or can tell me which cable should go and how it should go?
The one on the left is what they should look like.
thank you
![1717935649550.jpeg 1717935649550.jpeg](https://clio197.net/data/attachments/150/150809-a5487dbee0bc33526bb925a6b36332b7.jpg)
thank you
