Powerflex Upper Gearbox Bushing Install- Stuck
Kalamat88
Hi everyone,
Has anyone tried this particular install? It’s for the upper gearbox mount located beneath the battery and battery encasing.
I have the gearbox raised with a piece of wood on the jack and I’ve been adjusting it up and down the entire time I’ve been toying with this. Anyway, I’ve got the bolts out but I cannot even get the bracket and bushing out for anything! I’ve tried popping it on the head after loads of WD40- nothing. Then I read on ChatGPT that the middle thread is fixed, do you have to yank on the bracket and bushing till it separates from the thread. I dunno what to believe.
Then after giving up on pulling and trying to get the bracket to break free, I gave up and tried getting just the entire aluminum casing up and out- so I removed the two bolts to the right. The one on the top right was a pain in the ass and I loosened some of those brackets that hold the wiring looms to wedge my rachet in there to unscrew it. It came out (next post).
Guys I have no idea what’s going on with the photo uploading but it’s all over the damn place. Basically in the last post, the latter 2 photos show a bolt that is underneath the whole aluminum bracket that the upper gearbox sits on. It seems like this is keeping me from yanking it out. Is it worth undoing this or is there a better way to just remove the bracket and bushing?
Is there a better way to get this bushing out? Either I remove the entire aluminum bracket or I try removing just the bracket and bushing? Any tips much appreciated.
To remove the gearbox vibration mount, start by loosening the nut on the spike until it’s almost off, with the top of the nut just above the threads—this protects the external threads and the spike’s end. Position a jack or support under the gearbox, close but not touching it, for safety. If the nut is still on the spike, the gearbox will drop, but the nut will prevent it from falling completely. Then, using a hammer gently but firmly, tap the nut downward just enough to break the bond to the mount without causing damage, letting the gearbox’s weight assist.
Reactions: Kalamat88
Thank you, Turkie. Makes sense and looking forward to trying this if I get a chance tomorrow. Will post results for others that may find this useful in the future (if I can figure how to add photos properly) haha
