first question is the oil cooler pipes right as doesn't seem like its going to flow ie the clio goes into one rad pipe then out on the other rad pipe so in theory should flow around?
the 2 vacuam pipes coming of old clio engine where do they go on megane engine
what goes onto the end of this?
this is the plug for vacuam thing that is over the drivers side which the megane has over the passenger side (4th pic) should I use the clio one and exstend the pipe or use the megane one and exstend the wire?
any help would be greatly apreciated
