Part number required
Is there a workshop manual available on here?
I need the part number for the screw/bolt/rivet that holds the coolant tank in place, mine is missing and the tank keeps falling out of place!
you wont get that from a workshop manual...
phone a dealers parts department and they should know its only a plastic type of rivet!
Is there a way of getting to this hole for the coolant tank without taking front bumper off?
you might be able to remove the 2 top clip/rivets that hold the top half on the bumper on the slam panel section and lift up and get your hand behind/under the nose section to get the rivet in....but not tried it so not sure it will work...
