Oulton Park Cage and harnesses
Hi, just getting around to putting my cage in and wondered where everyone put their harnesses onto ? As seems most mounting points are taken with this cage and a rear brace
I don’t think there’s any horizontal bars on the Oulton cage.
You’d have to get fittings added to the floor (as long as the belts sit right), or a harness bar added.
Either change the cage or see if you can get a bar welded into it.
You can fix them to a bar that spans across the rear suspension but it’s best practice to have them to A cage
There are two mounting bars that go under the triangular plates at the bottom of the rear stays (these bolt between two rear suspension pick up points). My harnesses loop under these bars. It's not ideal as the harness angle is right on the 45 degree limit and a suitable cage with harness bars is on my list of things to do.
