Need help with 197 exhaust tips !!
So as much as I like the rear diffuser on the 197 I would love to fit a set of exhaust tips/extenders so my exhausts do not point down but come out from under the diffuser , just like the clip 200 , after hours of searching for suitable extenders I can't find any , can someone who has done this please help me with where to get them from and how to fit them
I would like them to be similar to the image below
Cheers guys
Just fitted these myself look pretty good
very easy to fit and can't go wrong for the price
the add is a bit misleading as it say's stainless and is infact ali
I received these today and I don't know if I have filed them down too much as they won't tap on....they would go all the way on. I bought a jubilee clip but they won't compress the Ali.
Any ideas?
Didn't think you could file too much off i filed them off all the way down & they were still tight
but if they are too big try bending the parts where the bolt holes are in with a hammer & punch
do both sides of the tip to reduce the internal size
good luck
I had them tips on my 1st 197 I filed mine down a bit to much and seemed to lose,so I drilled a hole though
tip and OE exhaust and put a screw it,you will need a strong drill bit as the OE exhaust is really stuff to get though.
