My front discs have cracked!
Hello my fellow forumers,
Help please - I need some new discs asap!
Not planning on track use, just discs for my normal daily drive (country roads).
What shall I get?
These are the Brembo pads I went with (Brembo part no P68036) http://www.apbrakediscs.co.uk/front...i-bm0-1-cm0-1-2-0-renault-sport-05-04-to.html @ £35.96
I paired them with the Brembo discs you linked above (Brembo part no 09.8904.10) http://www.apbrakediscs.co.uk/front-brembo-brake-discs-renault-clio-iii-2-0i-16v-sport-rs-06-on.html @ £69.25
You might want to get a new calliper pin kit (Renault part no 7701208118 - you need two of them), as they can bend and warp in the callipers through use and be a nightmare to remove, let alone get back in, I got http://renaultpartsdirect.co.uk/products/Renault-Clio-197-Brake-Pads-Pin-Kit-(Front).html which is two sets.
You might want to give the discs a lick of paint on the mounting bell (NOT the disc itself!), the Renault versions of the same discs have black paint on them but are around £120.
Genuine Renault Disc's & Pads from Wolverhampton Renault are reduced at the moment. £182.24 for the lot and that included delivery when I looked.
Thank you very much. I have just ordered discs and pads. I had the pins out today. And came out really easy so cleaned them all up and placed them back in.
Could someone please tell me what size Allen key socket I need to order?
Thats a result, the pins are usually a nightmare to get out if thet are not properly maintained. :smile:
