I Did a 200 at the weekend on the drive using car ramps was pretty easy to do with minimal knowledge
the only bits to remember is that you have to cut the oem system as close to the beam as possible , so you can get the exhaust over the rear beam
I undid the front pipe and middle hanger so the exhaust dropped I had enough room to clear the cars body when cutting it then.
The car I did had a decat pipe so I had to remove the oxygen sensor this can be a pain , I undid the wiring and removed the sensor when off the car " if stiff wd40 it and tap exhaust with hammer , not the sensor !! , you can also apply a bit of heat and
work it " the only other advice is to wd40 all nuts and bolts and let them soak and get someone to help when taking off the backbox its blooming heavy !!
