I would presume you'd be better off to just swap the whole engine. Like Foxspeed has said there are internal engine differences + your engine is mapped for a 7.5k RPM N/A engine, but your wanting to dump a ~6k RPM Turbo on to it.
I'm sure someone more qualified will be along soon to prove me wrong
I'm sure you could use/modify the Megane manifold and fit some low comp pistons. I've heard that the Clio ecu can accept a turbo as it has Meg bits in there already.
It would be an awesome motor, loads more low down torque and much higher reving than the Meg engine.
There's prob loads I've not considered so over to the experts.. Lol
dont think they use standard compression do they or if they do will be running a "low boost" set up to protect the engine as the 172/182/197 run from 10-11:1 c/r iirc
