massive oil leak
choppen
noticed a puddle of oil under car yesterday today driven it 2 miles left it for 10 mins and there was a massive puddle under it is there a common place where it chucks out loads of oil? not overly bothered as im pulling engine out shortly so don't want to spend loads of money on it but if its a cheap fix ill do it
thanks
in short no. u might wanna check the sump, sump plug or maybe even the drive shaft seals. my passenger drive shaft seal went and it left a mess with it
ive looked round the filter and it doesn't look like it is but only leaks when running pressurised so could be it am going to get it on a ramp and have a proper look
the oil leak was the filter come loose that also loosened the oil cooler bolt so all tightened up and fixed now
