Hello how do you fix when map sensor on 197/200 is loose any other way than zip ties?
ZorkoRS197 Dec 7, 2019 #1 Hello how do you fix when map sensor on 197/200 is loose any other way than zip ties?
B Bro Paid Member Dec 7, 2019 #2 ZorkoRS197 said: Hello how do you fix when map sensor on 197/200 is loose any other way than zip ties? Click to expand... I've replaced the o rings inside to slightly thicker ones. They seem to keep it pretty secure Sent from my SM-G950F using Tapatalk Reactions: ZorkoRS197
ZorkoRS197 Dec 9, 2019 #3 Bro said: I've replaced the o rings inside to slightly thicker ones. They seem to keep it pretty secure Sent from my SM-G950F using Tapatalk Click to expand... hello can you please tell me whit what size of o rings did you replace whit?
B Bro Paid Member Dec 9, 2019 #4 ZorkoRS197 said: hello can you please tell me whit what size of o rings did you replace whit? Click to expand... Hope this helps a bit. It was a long time ago since I did it. The clear gel stuff was a little bit of silicone sealer I think just to make it a good fit Sent from my SM-G950F using Tapatalk Reactions: ZorkoRS197
ZorkoRS197 Dec 9, 2019 #5 Bro said: Hope this helps a bit. It was a long time ago since I did it. The clear gel stuff was a little bit of silicone sealer I think just to make it a good fitView attachment 137638View attachment 137639View attachment 137640 Sent from my SM-G950F using Tapatalk Click to expand... Thanks! Im will change the o rings i also found interesting option of fixing map sensors being loose if anyone is interested it coud be worth checking out this picture Attachments Screenshot_20191209_223430_com.android.chrome.jpg 682.8 KB · Views: 90
