Just picked up this little gem few niggles to fix
Hi all new here. Just picked up a 07 clio 197 and what little ripper it is! Such good value for the money. Anyway few things need sorting first off is the heaters only blow on hot and all the speed setting work apart from 2. Any ideas? Also the door handle button doesn't seem to lock the car. Any help appreciated cheers Adam.20190623_191941.jpg
Welcome! Looks nice mate.
The door handle thing is very common, I find mine will work for a while then not work, I'm sure people have just cleaned around/behind the button somehow and that's fixed it as I think it's just dirt that gets on the contacts or something?
The blower thing is also common, I'm sure if you searched on here you'd find a fix!
Reactions: Adam Dagnall
Welcome! It’s usually water ingress that causes the door button issue...try spraying some wd40 in the gap around the button to see if that helps.
Loving the angel lights! How do you find the light output at night?
