is it possible? if so how?
is it possible to remove just the bottom cushion/base of the recaro and if so how is it done? i need to do a bit of a repair
thanks
thanks
it is swapped mine over last month
4 hex bolts (5mm allen key size) under the seats - takes about 30mins to swap both
fox speed in that thread did you actually change the whole bottom cushion or something? or get it reupholstered?
just mention done this now took 15 mins to get off and same back on
had this when i bought it
now fixed
just swapped over the whole bottom cushion assembly off the seats - passenger side is now drivers side and vice versa :thumbup:
I'm only getting drivers side seat so wont be able to do the same but will take care to look after the bolsters after all the reports of wear & tear, i'll be getting out my car like john wayne :wink:
now fixed
Just so people know, this is (for me) a 2 minute fix and I'm more then happy to give tips. Its just a rubber strip running round the bottom and is used to over turn the fabric to give a neat edge and wedges in a 'valley'
Its not a rip or damage or anything like that, just how the cover was design to fix in, and sometimes it can pop out with people getting in and out.
Steve
