Ipod for the 200
MissMagpiev6
Merry crimbo peeps. Quick question. I'd like to get my iPod connected up to the 200, also my HTC one too but I'm unsure how to go about this. I remember seeing two Jack sockets in front of the gear knob? please guide me, I'm utterly useless when it comes to this stuff! Thanks :smile:
Sounds like you have the std stereo if you have the jack points.
The only way to connect your iPod is to get a apple to phono lead. The steering wheel controls won't operate the iPod though.
Best solution is to get an aftermarket head unit that is Apple compatible.
This is how my iPhone is connected. I can play my music through it and listen to calls on loudspeaker. Don't have any control over the iPhone using the Clio controls other than volume obviously. Just connects via the headphone jack. Can't remember what the lead is called, I picked up the lead from asda so I can't imagine it would be hard to find. Found it around the AUX cable area. Once connected select "AUDIO" on the source control and enjoy.
I have a cheap bluetooth mod for the Oem unit, I did a couple of guides on Cs if you don't fancy a new head unit.
