Hub centric spacers
Big Ben
Loves to rag the VAG!
Can anyone help me?
Been looking at 5mm hub centric spacers for my 197
Two different bore sizes are coming up. 5x108/60.1 and 5x114/66.1
Anyone know which is correct?
You actually bought these yet @Big Ben ?
The ones I bought (At same price) were spot on and fitted perfectly without being multifit like the ones you linked too.
If you want a link just alert me to this thread again....
Standard are 28mm from memory.
So just get standard + the extra length of the width of the spacers.
Hence I bought 32/33mm for the fronts.
Were needed to - as standard bolts only had about 4 threads in the hub with 5mm spacers.....
Reactions: Big Ben
Cheers - doesn't bear thinking about!
More money to spend! Can you link me up please @sevenfourate. Was going to hope standard were long enough but not worth risking it!
I looked and couldn't easily find any 33mm long bolts with tapered 19mm heads @Big Ben
So i ended up buying new bolts back and front in 17mm head size.
Front for 5mm spacers:
http://www.ebay.co.uk/itm/172216685964?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
Rears for no spacers (I had stub-axle extenders):
http://www.ebay.co.uk/itm/182143790064?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
Reactions: Big Ben
