Makaveli160
Ever since i left my car in gear instead of the handbrake over last winter my gearbox seems like its on its way out.
Now im not necessarily blaming leaving it in gear but thats when i first remember it starting to play up.
I have read numerous gearbox threads on here with them going worng etc.
But i want to know if there are definitive symptoms that your gearbox is f***ed, or could it be things like slave cylinder, master cylinder, clutch?
Mine used to be abit funny going in gears etc when cold, but as soon as it was warmed up no problems and everything was smooth.
But the last year or so it seems to be getting worse and worse.
Its difficult getting into first gear when i set off first thing (can be notchy and feel clunky), when changing gears the gear changes arent smooth anymore in most gears it feels notchy and clunky. Sometimes when changing from 1st to 2nd it almost feels as if something pulls the car back like there is resistance.
The car doesnt feel happy about down changes either anymore (which has been going more than a few months now). coming from 6th to 4th for example sometimes it just wont go in gear the first fews times and i have to take it out and try again, same with 3rd gear aswell. Pulling up to roundabouts and dropping it into first, it doesnt like it when the car is moving and is sometimes smoother when completely stopped then into first, where as it used to be fine.
I have to be very delicate with it until its up to temperature, which used to be alright but now its notchy/ clunky/ slightly grindy when warm sometimes aswell.
Just read soo many posts about these gearboxes is worrying as my car is completely out of warranty and is going to cost an arm and a leg. So would rather get some opinions on other things that might help.
Are you meant to change the gearbox oil, or does the oil last longer than the gearboxes. Has anyone changed the oil and seen an improvement?
Really not having much luck atm, hit a dead animal which looks as if its caused a leak (still getting to the bottom of this), some complete wa**er has hit my car and clearly just driven off (three times my car has been hit without me even being in the car!!, 3times not my fault 2 of them i got money for this time i cant prove who it was) and thirdly the gearbox is really starting to PI55 me off.
