High level brake light out
Hey guys high level brake light went out tonight. Just wondered if its bonded on? Cos I've taken the little rubber grommets out behind it to find no bolts.
Anyone replaced theirs? Cheers.
Once the gromits are removed use a screwdriver to push a metal clip in each hole and the entire light will come out including the washer jet, pretty easy once you figure it out :smile:
It is right ball ache to get the light out first time you do it. As the previous post, remove grommets, then there is a silver tab that you push up with a screw driver, and you pull the light unit as you push the clip in to release the unit. I have one in my shed that I could take a photo of, if you don't figure it out. Don't worry about the metal clips coming off the light unit as they just push back on.
