Hi Guys,
I haven't posted on here for a while so hope all is well.
I have a 2006 197 with 65k on the clock.
The majority of the time its been a reliable engine but for the past year I have had this intermittent starting problem which over the past 1 month it has got worse and worse.
You can go out somewhere and it starts fine then I could start it again and it's tries to start but doesn't fire up and then the warning lights come on saying ESP and TC control disabled, airbag disabled etc. I have had to get towed 3 times. Each time prior to that I have had to call out green flag and they used their battery booster to start it and it started fine even though when I used my jump leads to my friends car it didn't start. I happened 3 times this week.
To cut a long story short I need to know where the starter motor is in the clio 197? Yesterday I removed the battery + box (which is only 1 week old), both air intake pipes, checked fuses, removed airbox and all the loom looks fine. I also read on different forums that it could be the TDC/ crank sensor in the gearbox, I have checked this and cleaned it and all is good.
The car is stuck in my garage and wont start. If anyone has had this problem again and can share any advice on how to diagnose this that would be much appreciated.
Chris
Chris
