Hello and sorry to start with a question
Hi. I part own a 197 track car and after a cracking run round oulton today encountered a gearbox issue 1 mile from home. Car got stuck in 4th gear and would only come out after having to stop the car and bang the gearstick into neutral. It then drive fine back in 1st, 2nd and 3rd but immediately had the fault again in 4th when trying the box on the drive with the engine not running.
I have put a video on YouTube of the noise that is apparent when the engine is running, in neutral and with the clutch both pressed and released.
If anyone has any help or info as to where I can learn more I would be very grateful.
Sounds like you might be lucky and one of the gear linkages has popped off the box, have a look at this thread
Yea, check the linkage first - behind the battery. Make sure nothing is obstructing it, and the cables are still secured.
Thank you both for your replies and the thread hint. I will be having a look this weekend and will post the outcome in case it can help anyone else.
Had a look and it wasn't anything blindingly obvious. All linkages looked how they should be and the selectors look ok too. Think it's going to have to go off and be looked at by a specialist. Does anyone have any recommendations for gearbox people?
If you are anywhere near Essex you could contact AW Motorsport via Facebook. They did my gearbox and Gripper at the start of the year.
B New Members 2
joshneville New Members 4
Kanazir New Members 6
C New Members 4
N New Members 4
