Headlights
I might be looking to upgrade my lamps at some point but a set of projectors and the associated bulbs etc is abit steep. Whats the best bulbs i should be looking at as a direct replacement??
Ive put HID's in mine, just make sure you check the levels and beam pattern is correct and theyre fine. I went for 6K for a white/very pale blue look.(had them fitted in my passat)
They will be better than any uprated bulb, but as said i used to have Osram Nightbreakers in as my high beam, and they were v.good.
HTH :smile:
Main Beam are H7 and high are H1 irrc?
Dont get a HID kit with the standard reflector headlights, the beam pattern will be very poor.
