Headlight Beam (Projectors)
Could somebody take a photo from their drivers seat showing the pattern of light?
Im sure mine was nearly totally linear with a 45degree angle up onto the verge on the offside but i swear the drivers side has dropped significantly...Just cant be sure.:001_huh:
Ta
Passenger side is like this \_ and drivers side has a shape more like this -_ however you can still see the \_ shape on the drivers side but just not as brightly
the lowest flat point on both lights should be level
I.e they should look like this (Obviously this image is for LHD and yours should flick up to the left)
if the beam is going odd it could be the bulb filament thats started to miss-shape causing the pattern to change
