Had the mot booked a few weeks back and thought most was ok but upon inspection with wheels off found the rear calipers ( which I knew there was an issue with due to the surface rust on them) to be fubar'ed! Tried to release the pistons but well gone! So I hit the yards and my local supplied me two second hand ones for.....wait for it.......£30! Perfect order, bargain, even came with the caliper housing and a set of renault pads with about 1mm wear!
Near took his arm off! Fitted them and the rust is coming of the discs nicely now I've planned new calipers, discs, brake lines, shocks, drop the rear axel, front subframe and suspension components and vapour blasting this summer to get it all looking like new again
These will do the trick for the winter as I didn't want to start putting new stuff on for the salt to mess up
Also had the BIG service due too, belts, pump etc the lot! So I snagged the the full kit on a Black Friday deal from RPD along with filter plugs and a few other bits for £330 and my mechanic has just fitted the lot (apart from the calipers! As I did that) serviced it and checked it for the mot for the grand total of £120!!
So for around £500 I've just had the big one done, a near new set of rear calipers on the car and a fresh MOT with no advisories!
Well chuffed
Well chuffed
