H&R Spring Question
Gez
Moderator & South Wales Rep
Hi all,
Quick Question for you all,
Are the H&R springs the same for all 197/200 models?
I've got a 2012, smaller top mount.
Just making sure if I need specific ones or if they're all the same?
Thank You
Gez
The springs changed when the changed the top mounts, so you will need to buy the specific ones.
Give Tony at Demon Tweeks a call, he sorted mine out for me :smile:
So are those 30mm drop front and rear? Some seem to go for a 30/40mm drop, is that kit available from H&R, or is it made up separately?
