A2ON
Hello chums ,
Just a quick question for you H&R guys
Brought some hub centric hub spacers x 4
and they seem to bolt to the hub then the wheel to them !!
This is nothing like i have used before usually use longer bolts etc
I have some questions
1- on a track day you normally torque and re torque wheels throughout the day however of course the wheel can be tight but the spacer could be loose only way to test would be to remove the wheel then meaning you need to check it again ! is this right ?
2- whats the recomended torque for hub to spacer bolts
3- has anyone used them on track and been ok ?
Arron
Arron
