Gearbox crunch
Fuchs Titan Sintofluid seems to be well recognised, but to be honest if you are having a crunch then it is unlikely to make much if any difference.
If its a proper crunch then no oil will help you, if its just a notchy feel then changing oil might help.
Have a search though, this has been covered so many times as its a very common problem.
However I would not recommend Fuchs, it made no difference in mine and imo is just as good as the Elf oil that's in the box already. I would instead try some Red Line MTL as this is supposed to help iffy gearboxes change more smoothly.
thanks guys, its still under warranty from the garage but its a 57 plate car so i dont think ill have much joy.
I added the fuchs to mine last week. It has made the box quieter. However I wasn't having any issues with the gearbox beforehand, it was just something I wanted to change.
Try and get it repaired mate, if you have a warranty then it should be covered.
This will be my last RS I think, getting tired of all the little niggles now that all add up.
