Front wheels tracking set up
Got some new tyres last week but have now noticed I have a slight steering wheel wobble at 70mph +
Figure its the tracking.
There is a long old sticky thread in here about wheel alignment - can someone just confirm that these are the correct settings. Ta
I have the cup pack (or 'extreme pack' as the workshop manual describes it) so the desired value on the front toe out is -0°12’ ± 12’ whereas at alignment centres it is -0°05' (+/- 5')
The other values in the manual correspond with what they give at alignment centres:
Castor Angle: 5°38’ ± 39’
Camber: -0°59’ ± 30’
Apart from the toe values:
Toe: -0°10’ ± 8’ (non-cup pack)
Toe: -0°12’ ± 12’ (cup/extreme pack)
Anyone run this front Toe value on theirs?
The camber value on the rear is the same in both the workshop manual & what alignment centres go off of
Camber: -1°33’ ± 20’
But again the Toe is different, alignment centres have the toe as 0°15' (+/- 15')
In the workshop manual:
Toe-in: 0°31’ ± 30’ (same on cup/non-cup)
it was there before - not as bad - put it down to the V12s constantly going down.
Wheels been spun and balance so put that out of the question
Turns out my wobble is from the two front wheels have dents in the inner rim which caused this. They rebalanced them as best they could and stuck them on the back.
Cars much better now
