Apologies for the high jack.
I am also looking for some new bulbs for my 2009 RS200.
Can someone please let me know what fitment I need?
Main beam - ?
Dipped beam - ?
H7’s for both on standard 200 lights.
On projectors it’s H1’s for dipped and H7’s for main.
Thanks for the pics. I think the bottom pic is what I am afterwhat headlight are you on about? Pictures of a projector
H7 Bulbs
Hahahah.Headlight clip porn if you are sexually aroused by these photos then you have been self isolating for too long. To have a broken headlight in the room with me to photograph, I think I've been inside too long.
They are reflectors. I will have a look.You need to make sure the bulbs are fitted correctly the other thing to check if you can see through the lens is the bulb in the centre of the ring if someone has been fitting the bulbs blindly they could have bent the metal arm with the ring and can dramatically cut the beam pattern. The other thing could be if the bulb is fitted upside down, it's very hard to feel if the bulbs are fully seated unless the headlights are taken out bulbs fitted and put back on. You can put your finger in to correct the ring/arm what colour is the wires inside the light they will be blue, red or yellow. Blue is reflector lights, Red is Projector lights and yellow is Xenon lights as far as genuine Valeo light are concerned.
Can you do me one more favour?You need to make sure the bulbs are fitted correctly the other thing to check if you can see through the lens is the bulb in the centre of the ring if someone has been fitting the bulbs blindly they could have bent the metal arm with the ring and can dramatically cut the beam pattern. The other thing could be if the bulb is fitted upside down, it's very hard to feel if the bulbs are fully seated unless the headlights are taken out bulbs fitted and put back on. You can put your finger in to correct the ring/arm what colour is the wires inside the light they will be blue, red or yellow. Blue is reflector lights, Red is Projector lights and yellow is Xenon lights as far as genuine Valeo light are concerned.
