Fog light access
How do you get to the foglights to change the bulbs?
The only way i can see it to take the arch lining off, which is held on with non reusable plastic rivets.
are you sure over the non-reuseable plastic rivets - had my liner off and reused them......
...did the same...got the rivets out carefully....they can be re-used. Halfords (or similar) sell them anyway so you can replace easy enough.....check out the LED replacements on bulbsdirect....probably not strictly legal but will look the nuts and will give a good light!!
