Finally picked my Raider up!!!
Finally went to get my Raider this morning. Sad to see my 200 go but the new one is worth every penny! Only had 6 hrs to do something with it so here goes.....
First up was the initial wash, car was quite dirty as it hadn't been washed analy first time round so i requested just to leave it till i came for it. Cant really see how dirty it is but a matt finish that hasnt been treated looks very shabby in areas
Wheels however were the familiar signs of a new pad
Bilberry was diluted at 10:1. Had to make a temporary brush out of a wash schmitt as i had sold my Ez Brush, forgetting that Polished Bliss hadn't received their wheel woolies yet :@ Swissvax style brush was also used
Still got the job done for now and got them clean enough. Arches were also done but they had been treated to something so using just shampoo and another homemade brush sorted it but with no pics.
Next up was the body work, not many pictures here but used the shampoo that came with the car, a Swissvax mitt and cleaned the usual intricate areas and badges & sills/shuts with several brushes
The car was then moved into the valet bay and i just timed it right as it started to rain. Full car patted down using a few small microfibres
Washing and drying has taken up more than 2 hrs for some reason. Maybe i was being too careful so i had to crack on with the paint. Opaque cleaner fluid was applied to all matt areas
Spraying on every panel and wiping off, turning the cloth frequently to buff off excess using the Swissvax cleaner fluid towel
Full car was then completed and ready for the Opaque wax
The 50ml pot that comes with the discovery kit does seem small just like the autobahn but a little goes a very long way. Put this on with the black applicator pad and took it off using the blue wax cloth that also came with the kit
Putting this on actual matt paint as apposed to vinyl wrap was visually different as it didn't significantly darken the area as it does with vinyl so there was a very slight darkening of color but was very hard to capture, even with the wax on
Left half of the bonnet
Better pic of the small section on the left hand side
Lot of hard work indeed for a full car. Timing needed to be right for every panel as you can't let it cure. The car needs a full re buff after a few hrs as the wax needs to gas off. This could be clearly seen and looked a bit milky in areas but i couldn't really capture the finish and didn't have the time so i moved on to waxing the shuts and sills etc.
By now i had used up 6 hrs! and there was just a little too much to finish in the given time so the gloss areas and wheels were treated to a bit of diluted c2 1:1 as a temporary measure until i can give the areas a once over with the rotary and get some autobahn on the wheels. The show plates that were taken off the car had left remains of the double sided sticky pads so these were removed, taking extra precaution on the rear because it was stuck on the matt finish so i didn't use a tar/glue remover, just heat. New private plates were put on that i was chuffed to bits with as it makes it look that bit more special. Final wipe down of the car was then done after an hr and a half of being in a bit of sun. Few pics of the more or less completed work .........
Most importantly, keys were handed over by the salesman himself
Sorry for a few gaps with no pics but did take a hell of a long time! Comments welcomed as always :biggrin: Lew
Looks class! Good to see some good products being used on it, looks like it's going to be looked after well!
Plate is good to!
Looks fantastic mate 8)
I sadly would not have the patience to keep the paintwork looking like that as id be too worried id fook it up!
Top work though.
Carbon exhaust tips would suit it no end!
very nice car, the detail looked good as well, good luck with it!
what tyres come on the car? are they the same as on the new 265 megane trophy?
Top work though.
The Akrapovic system is tempting me at the end of the month but we shall see yet :drool:
Looks good that, all the best looking after it, at least you know what your doing.
They let you detail your car in their garage? Brilliant.
Like the plate too! I really want those wheels.
May need to pm you regarding products you've used Lew.. As mine could do with a good clean honest to good they attract dust like mad. As for the plate you beat stupid really when it was silly cheap.. :@ lol
