ESPACE rear discs???
Anyone familiar with the possible fitting of ESPACE IV 3.5 rear discs in a 197 ???
they are 5x108 iirc and the diameter is also 300mm and thickness also 11mm, I can get a set for a third of a price of a single clio OEM disc so wondering if there is a chance that these will fit straight in......
any help appreciated, thanks!
for example: ATE rear discs complete with bearings and ABS ring:
diameter: 300mm - ok
thickness: 11mm - ok
minimum thickness: 9,5mm
wheel stud: 5x108 ok
now other things might need checking: height 84,7mm
thread size M14x1.5
inside diameter 52,3
hmm...
a set for around 100 pounds
what about bearing size....espace is a bit bigger than clio and alot heavier...
what about offset, wouldnt this effect the position of the disc to the caliper
