I think thats the one. on the left side of the rev counter. When I turn it on this one seems to take a couple of seconds longer than the others to turn off - Is this normal ?
Yes 8) it checks all the engine sensors if they are working correctly. To check them the engine needs to run so they send data to the ECU. If the light stays on....then you have a problem :biggrin:
