Electronic fault on dashboard.
Hi,
One of my door lights had broken and got jammed when shutting the passenger door. I have since changed the bulb and changed the interior fuses but to no avail.
Now none of my interior lights, automatic headlights, or boot are working. There is a message saying electronic fault and the wrench light stays on.
Any suggestions?!
Ok so I reset my battery and now the electric fault is away, but still nothing is working. So I tried all the fuses with a multimeter and all seem to be fine.
I read somewhere that on a multimeter some fuses appear to be fine but infact have blown. Is this the case?
if you look in the manual pg 5.20 theres a couple of fuses that control the items you say are not working
as for testing them - nothing better than substitution of a known good one!
there is also a secondary fuse box under the second air inlet on the n/s/f side!!
