I changed the misses pads on the golf mk 5 2.0 tdi. They are exactly the same as clio but come with a bit more meat on from new. Mite help you widen your search? Unfortunately I've chucked the olds already
I haven't fitted them to the clio, but they looked so similar got the tape measure out and then double checked the sizing on ecp / nextday brakes. Sure enough they are mm perfect . The discs may be thicker on the clio whuch might explain more material on the golf ones to start.. golf ones are cheaper too..
i should have some within the next couple of weeks! pads are fine, just the disks are worn! ill let you know when there changed if your still after one! :thumbup:
