Dent :(
Ok chaps, need your advice
I have this dent:
Whats the best way to get rid?
Should i just call chipsaway or is there an easier way to pop it back out?
:001_unsure:
dents away/paintless dent removal will get that out mate :smile:
I had
turned to
Let them know they can go through the speaker hole at the rear seat and should be able to get it
That is impressive.
Any idea what that will cost? If im going to call a dents/chip guy out i may as well get my stonechips fixed i guess.
Mine cost around £35 even came out to my work carpark was done in about 30 minutes! getting stone chips out is different and if you get someone that does a crap job you'll need a full respray. The dent as long as no paint is missing just gets pushed out :smile:
I had a small one along flank line like a door dent got fixed up a treat nothin like that though but I'm sure they could do it!
You may be better posting on a few websites, here, Pistonheads, etc. for a recommendation for a paintless dent repair in your area. The franchises can be a bit variable, the skills are all down to the individual.
Ye, look for an independant dent remover, will charge typically £40-£50 per panel. I had 2 done on my old Clio and the one you couldn't see, the other was just about visable.
I wouldn't use chips away for dent removal or anything for that matter. Messed up a repair on my 182 big time!!
Like has been said search for a local dent remover I used one locally with the 182 and they were great, £50 iirc
Lots of good feedback. Cheers people.
Have called a local guy to come out and have a look!
Will update after the work is done unless its a rum job in which case I'll update with a rant :smile:
