I would not worry about it. If you need the nut back off you just use a windy gun, I never use the hex part, you either do what you have done or snap the Allen key. Windy gun with a socket on when the suspension is under load, so the nut is hand tight, then when the strut is off and the spring compressed just un screw the nut, refit is the same, hand tight then windy gun.
