Marsch
I've ordered the Cup front anti-roll bar from the RS Performance shop as it was 15% off. The part that arrived is labeled 8200646060 and comes back as belonging to the Scenic II. The part number for the one for Clio should actually be 7711160155.
I've contacted Oreca which manages the shop for RS and they've now told me that the part must be mislabeled. They've sent me the following photo and assured me it's actually 7711166150.
It's very well possible that parts are used for multiple cars as you presumably know but in this case they often retain the same part number. It could also be an old/new replacement but you'd normally find infos about it then which isn't the case here.
Does anybody has any experience with this part? Would you take it and risk using it or would you rather return it?
