Took 6 minutes to get the box open and all out on the bench. LolDropped off my box last night, Marks a top guy even though he’s super busy, he has already split my box and discovered I have a Quaife diff!
He showed me how easily these synchros can wear with a Stanley knife too!
Hopefully these modified synchros are the answer!
Howzabout that for a turnaround eh!Gearbox collected.... Should hopefully have the box fitted early part of next week.
Will report back as soon as I can!
I’m guessing as a gearbox bloke he knows what he has hassles with and doesn’t...how do we know these syncors are better/ stronger?
how much you charge ? assuming we need to send you the box and you send it back?
I’ve been around boxes for quite some time now mate, so you get a feel for what’s good and what’s not. When you can remove the coating easily of the original synchro rings with a Stanley blade, I think it’s safe to say that they’re not really the best are they!how do we know these syncors are better/ stronger?
I always bang on about how important decent spec oil is in these boxes, and also frequent oil changes. In a race car the oils are dropped after every race - so why the fuck do we do k’s of miles on the same oil after it’s been given a shit kicking on track and on the road?! You wouldn’t treat the engine the same way would you?! Gear oil needs to be treated as a consumable.
Thank you mate, very kind words.Having seen this first hand, you would not believe that its actually like a hot knife through butter!
The gearbox oil @Northloopcup recommended is nice and thick, ideal for track driving. The gear changing even from cold seems absolutely fine.
I can not recommend @Northloopcup enough for his gearbox knowledge and rebuilding skills! he knows a lot about all the Clio gearboxes.
He also turned around my box rebuild in pretty much 3 days in the middle of the week!
Only issue for me is he lives over 180 miles away from me!
On 3rd and 4th? If so, then yes.Can I ask if the syncros are the same for each gear?
Sent from my EVA-L09 using Tapatalk
No mate different again as is 1st. They’re double synchromesh. No 2 synchro rings in the tl4 are the same.Even for second?
