@samben Mines set to a standard Bosch 60-2 trigger with 84deg crank angle, and 0 crank offset.
Next time it's mapped I want it verifying with a timing light though, as I've heard I should have 8deg crank offset on that. I'd be interested to know what your DTA ends up being set to?
I assume you tuned the F4R then, what cams did you settle on in the end?
