Dean Cohen
Should it be there all the time?Needs to be here. Actual water temp can be seen at the bottom of the pic too. Usually circulates between 77 and 80
as mine only makes it to the second line if i'm idling, in stop start traffic or driving the car very hard. otherwise is sits on that first line when doing normal driving cos it has been that way since I got the car, never questioned it till now.
What do I need to replace and where?
sorry if it seems like a 'noob' question but am a bit new to the whole car thing
my car never goes below #2 but will sit perfectly on #2 for the majority of driving unless doing any of what I mentioned in my previous post and I mean it will not move from #2 unless i'm stationary or getting every last RPM out of each gear.
Thanks for the replies and apologies for hijacking the thread
But I'm a bit confused now as to the 2 slightly different responses, going by turkie's pic:
so my car is sitting on the very bottom of normal 90% of the time? does my thermostat need replacing yes or no?
It's like 8 quid for the replacement part from eurocarparts.Okay so my thermostat does need replacing. is there anything wrong with driving my car as is? as Xmas leaves the car funds quite low.
I always wait for the car to get up to temp before I start stretching it's legs, unless I've lost my patience with the stupid amount of roadwork and 20mph speed limits around.
Everyone is so busy looking at the temp gauge illustrations nobody is looking at the average 39.5MPG![]()
It’s the car trying to be as cool as it’s ownerI was, and I do all motorway @ 75miles a day and have never got that (well my gauge chats crap and says 31-33mpg over so many journeys, but fill ups always say 36-37mpg).
Also my thermostat is going AGAIN, it's a yearly service on my car, but I do like 20-22k a year!
Perfect explanation thank you, Mine sits around line #3 all the time I wasn't sure if it should be directly in the middle but all seems good on my end!When you start the car first thing the temp will go up to almost line #3 then drop that's the thermostat opening and colder water allowed in, the temp will drop back a bit but should run above the line #2. If it sits below line #2 during normal (non aggressive) driving that's not normal, at lights the needle will come up to line #3 maybe level or just over and the fan should kick in and that can be earlier if the aircon is on but again normal. The older 172 Clio's used to sit at line #4 and never moved the 197 Clio's run cooler.
That was sat behind my mates recovery van with the cruise on when I came back from Germany.I was, and I do all motorway @ 75miles a day and have never got that (well my gauge chats crap and says 31-33mpg over so many journeys, but fill ups always say 36-37mpg).
