Clutch fluid change
Antti O
Gold Member
So basically we have -20 now here and i am pretty sure my 197 clutch fluid is original.
Over time there must be some water in the fluid and it will freeze and then you have problems.
Brake fluid was changed 2012 may but clutch fluid not.
How difficult thing it is in 197 to do?
Does it not share the same fluid as the brakes on the Clio? I know a lot of cars do.
it does - but if you dont bleed the fluid from the clutch line then it will always be "old" fluid trapped in the supply line...
the fluid will only change or be topped up as such as the clutch wears and the slave cylinder moves to compensate for that wear
