Best way to bleed clutch fluid
aterro
Hi all
what’s the best way to bleed the clutch to ensure you get all the old fluid out?
thanks
Empty the reservoir with a syringe.
Could then either gravity bleed or use a pressure bleeder to cycle the new stuff through.
If you didn’t know.... When you bleed, you need to start as far away from the abs pump as you can.
So OSR, NSR, OSF, NSF
You should bleed the front callipers outside first, then inside.
The real way is to push the fluid up through the system towards the reservoir as bubbles will not go downward and get trapped in the damper/filter just up the line from the gearbox.
So would you say following this method isn't really achieving the goal of bleeding the clutch?
