Not posted on here as I've been struggling with my 09 RS200 cup since purchased 4 months ago. I've just had a new gearbox fitted by Renault due to crunching 4th gear. This was a month ago and have covered around 700 miles. From the get go the box was crunching and notchy from cold so drove it thinking it was new and needed to bed in. No change at the moment still and Renault seem to think there's no issues on test drives. They've stated the clutch was also checked during the box replacement. Doing research about causes of gearbox crunching I found out about clutch dragging. This seems to make sense as when the car is warm it feels as though the clutch is slightly engaging making it kangeroo while pulling away at round abouts and during acceleration. Anyway one test was to park your car on a flat road, put in gear, keep clutch in with handbrake off and then rev the car near red line. Apparently the car should only move just before the rev limiter but mine is lurching forward between 5-6k revving. is this normal for the rs200? The new box is crunching when driving over 4k revs and when changing at about 2k, it won't let me in 2nd gear sometimes for at least 2 seconds. Is the clutch dragging and could be causing crunching /notchy gear changes?
Cheers.
Cheers.
