Jack it up on the passenger side and see if there is play in the wheel. Try it at the 12&6 (top and bottom) position and also 3&9 (left and right). Any movement should help pinpoint your issue. Left and right movement points to possible Track rod ends, top and bottom suggest wheel bearing or similar. Also have a good check of your spring (not snapped) and shock. Been investigating something similar on mine and found a faulty track rod.
