Hi all,
Got a cheap Chinese CLiP the other day, been looking at what needs to be done to disable the airbag warning light once I fit recaro's. By the looks of it you lose the anti-submarining airbags from the original seats so I'm presuming that's the first two at the top, "drivers lap strap seat airbag" and "passenger lap strap seat airbag"...
Anyone be kind enough to confirm?
Also I noticed that everytime I do a new network scan my airbag computer keeps throwing up a multiplex network fault in its history, the fault clears ok but after a new scan it reappears?
Ignore the lighting fault on #989 that's genuine (rear height sensor again, grrr), wasn't sure if this was just a cheap knockoff CLiP issue?
I know if you try to connect with the ignition off you get the same multiplex network faults on the UCH / ABS etc.
