Clio 200t side lights
Thought mine had blown when I first got the car. But then I realised that it only appears to dim the DRL's when putting the side lights on.
Question.. I see though that it has "normal" side lights as well. Can you activate these somehow? Seems a bit daft to have both if you can't! Unless it's for markets where DRL's are not legal.
The headlamp units are the same as the standard car, and come with bulbs pre installed, but the car does not have the wiring for these. If you look behind them you can see there isn't any wire leading to them
