Is the diffuser a straight swap between the 2 cars? How much should I expect to pay for a used 200 diffuser?
The diffuser on my 197 has been melted quite badly by the exhaust tips i've fitted. Not sure why because they've been fitted for months, but only in the last few weeks has the melting started...
Here you can see what I mean:
The other side was much worse and once i'd removed all the melted edges and filed some clearance in, i'm left with a much larger hole in the diffuser than standard. The plastic above the exhaust tips has completely melted away on one side too
Hopefully i've given it enough clearance now and I won't get anymore ugly drips of plastic, but if it continues i'm thinking a 200 diffuser is the way to go to stop this issue.
