Hello, at the moment I stripping cables for a tracktool build. In the fusebox infront the battery there are 2 relays for the headlight washers. Can I remove them without getting any issues? The problem is I build a custom fusebox and dont know if the canbus need them. I cant connect clip or the battery to test it. The cup dont have the washers anyway. This is the last step before I recolating the battery in the back and this one is the last step. Silly question but I got issues in the past after disconnecting the pump from the rearwiper and the passenger window switch.
