New ARB is £95.22 inc delivery, part no. 7711160155.
If you have factory xenons with auto levelling you will need to modify your front level adjuster to suit the thicker bar.
Do not try this bar with standard [197 Cup] suspension, it is awful, understeer city. While the part itself is expensive it is time consuming to fit and then time consuming again to remove to refit the original part when you realise that the rest of the car isn't stiff enough to benefit from the thicker ARB.
You should generally speaking only stiffen the front when you have already stiffened the back; reading between the lines the benefit of a stiffer front end seems to be in part to balance out a tricky rear end.
Anyone considering this should thoroughly research the pros and cons of a stiffer front ARB before buying one. I didn't, I rushed in (perhaps partly on the basis of a recommendation) because we were dropping the subframe anyway, and for my car it was an enormous mistake. Aside from the cost implications it also ruined a track day as I just couldn't get the power down coming out of tight corners, so it isn't that the road was too bumpy, etc. which can also cause issues with a stiff ARB.
