Does anyone know if the 200 clocks fit in the 197 please without needing to reprogram the car? I want the yellow rev counter.
Cheers
John
Cheers
John
Thanks Sean, is this a Renault only job to reprogram please?
Sent from my iPhone using Tapatalk Pro
Cheers Eddie, ah well, I’ll just make sure I document the change for when I come to sell it.
Thanks again
So John, you've come on here hoping we're going to help you out and here we are making your should I?/shouldn't I? situation even worse!
As Davinder his rightly pointed out, you could always put 197 clocks back in and have the miles set correctly. You'd definitely have trouble selling if you had different clocks in though.
My advice if you are going ahead would be to document the hell out of it all just in case. Photos of the old clocks in the car showing the miles and the same with the new ones showing the same miles, and then vice versa at the end. Best to try and protect yourself for the future.
Should have just bought a 200 and changed the front end to the 197 [emoji6] I hope I haven’t offended 200 owners!
I also craped myself when the tool showed 120,000 at the start but when I did the math it was actually km and was equal to the display in miles.
I've done it and it's a straight swap but if the dials come from a cup it won't have cruise control etc. which will then need programming via CLIP. As mentioned you can put the mileage forward but not back via CLIP so make sure you check the mileage on the donor before you buy, I had to add about 10k to my 200 dials to match them up... Given mileage history is recorded on MOT it's gonna look a bit odd if it suddenly goes backwards so your best off getting it done right.
Dials are a two minute job to fit, if you have CLIP it will take you five and job done.![]()
Clio 200 - Replacement Rear Calipers? | Suspension, Brakes & Steering | 1 | |
For Sale: Clio 200 Clocks | Car Parts For Sale | 1 | |
Clio 200 Clocks help needed ASAP | Interior and Audio | 4 |
